Clearpass Cisco 9300 Client timeout
This thread has been viewed 22 times
  • 1.  Clearpass Cisco 9300 Client timeout
    Posted Mar 21, 2022 11:28 AM
    Over the last 2 days, I swapped out an older Cisco switch with a new Cisco 9300.  I have added the config for dot1x authentication.  When I add the config to the switch ports for client auth, I am getting authentication failed due to client timeout, no response from the client.
    I have verified the config for the switch on the Clearpass server is correct.  I have checked my config on the switch so many times.  I deleted the config and re-added with no change.   Here is my switch config:
    Global config
    aaa group server radius RASERV
    server name RASERV-1
    server name RASERV-6
    aaa authentication dot1x default group RASERV
    aaa authorization network default group RASERV
    aaa accounting dot1x default start-stop group RASERV
    aaa server radius dynamic-author
     client 10.15.64.218 server-key Aruba123!
     client 10.8.8.84 server-key Aruba123!
     port 3799
     auth-type all
    radius server RASERV-1
     address ipv4 10.15.64.218 auth-port 1645 acct-port 1646
     key Aruba123!
    radius server RASERV-6
     address ipv4 10.8.8.84 auth-port 1645 acct-port 1646
     key Aruba123!
    Port config
    authentication host-mode multi-auth
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    authentication violation protect
    mab
    storm-control broadcast level 5.00
    dot1x pae authenticator
    dot1x timeout server-timeout 10
    dot1x timeout tx-period 10
    Do any of you smart people have any suggestions?  Also I have searched everything I can and have not found where anyone else has posted same issue.
    Thanks in advance
    Michael McNeely
  • 2.  RE: Clearpass Cisco 9300 Client timeout
    Posted Apr 01, 2022 03:13 PM
    Have you looked at the ClearPass wired authentication guide here?  https://support.hpe.com/hpesc/public/docDisplay?docId=a00091135en_us
  • 3.  RE: Clearpass Cisco 9300 Client timeout
    Posted Apr 04, 2022 10:36 AM
    I have the following config running on a 9300 with no issues:
    dot1x system-auth-control
    ip dhcp snooping
    aaa group server radius CLEARPASS_radius
     server name CPPM1
    aaa authentication dot1x default group CLEARPASS_radius
    aaa authorization network default group CLEARPASS_radius
    aaa accounting dot1x default start-stop group CLEARPASS_radius
     client [cppm1 ip] server-key [key]
     port 3799
     auth-type all
    ip radius source-interface Vlan601
    radius-server attribute 32 include-in-access-req format %h
    radius-server attribute 32 include-in-accounting-req format %h
    radius-server source-ports extended
    radius server CPPM1
     address ipv4 [cppm1 ip] auth-port 1812 acct-port 1813
     key [key]
    interface GigabitEthernet1/0/20
     switchport access vlan 101
     switchport mode access
     no logging event link-status
     mab
     no snmp trap link-status
     dot1x timeout tx-period 5
     dot1x max-req 3
     dot1x max-reauth-req 3
     spanning-tree portfast
    Evan Fisher
  • 4.  RE: Clearpass Cisco 9300 Client timeout
    MVP
    Posted Apr 11, 2022 02:38 AM
    On the C9x00 Series, you need to create Policy Maps and assign them to the port. Here is an example of what we have deployed:
    policy-map type control subscriber CLEARPASS_POLICY_MAP
    event session-started match-all
    10 class always do-until-failure
    10 authenticate using dot1x retries 2 retry-time 0 priority 10
    20 authenticate using mab priority 20
    event authentication-failure match-first
    5 class DOT1X_FAILED do-until-failure
    10 terminate dot1x
    10 class DOT1X_NO_RESP do-until-failure
    10 terminate dot1x
    20 class MAB_FAILED do-until-failure
    10 terminate mab
    20 authentication-restart 60
    40 class always do-until-failure
    10 terminate dot1x
    20 terminate mab
    30 authentication-restart 60
    event agent-found match-all
    10 terminate mab
    20 authenticate using dot1x retries 2 retry-time 0 priority 10
    event authentication-success match-all
    10 activate service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
    Then, in the interface, the configuration looks something like this:
    interface GigabitEthernet1/0/1
    description None
    switchport access vlan 999
    switchport voice vlan XYZ
    device-tracking attach-policy policy-og
    access-session closed
    access-session port-control auto
    mab
    dot1x timeout server-timeout 30
    dot1x max-req 3
    service-policy type control subscriber CLEARPASS_POLICY_MAP
    Shpat | MVP 2021 | ACEP | ACMP | ACCP | ACDP |
  • 5.  RE: Clearpass Cisco 9300 Client timeout
    MVP
    Posted Apr 26, 2022 10:22 AM
    We have 9300 switches running without issue, didn't have to create any policy maps. I think your missing "dot1x system-auth-control" in your configuration snippet you provided. Is that on the switch?
    The other thing would be checking the end device connecting to the port, that device needs wired 802.1X enabled as well for it to pass credentials.
    Michael Haring
