clearpass cisco posture
  • 1.  clearpass cisco posture
    Posted Sep 05, 2014 02:59 PM
    hi,
    we have aruba controller and cisco swithc 3560with 12.2(58) version
    i have done all wireless configuration its working good,and i have created posture for wireless connection als its working good
    i want to create wired authentication for our emoloyee on cisco switch,authentication via our dc
    and i dont want to install agent in our employee ps, i want the cisco switch to redirect them to onguard port and check ,
    i have created wired service and policy , in the policy i have created a profile with cisco dacl template that check if the user is [user auth] and [mac auth] he will get ip any any acl
    and another profile that chek for posture if its healthy
    if all this match he will get full access
    second rule:its check if the tips[user auth] and [mac auth],
    and if the posture not healthy
    i dont know which profile should i assign for the second rule,
    if the user authenticated but its not healthy i want cisco switch to rdirect him onguard without installing agent and check his pc,
    could you please tell me what configuration should i do on cisco and clearpass profile,
    note:i dont want to redirect him to another vlan,, i want to use Dacl attr
    thank you
  • 2.  RE: clearpass cisco posture
    Posted Sep 05, 2014 05:23 PM
    OK, just keep in mind that the posture token is cached for a certain amount of time and the user may have to be manually checked every time they reconnect. The user experience may be frustrating. Is this the behavior you want?
  • 3.  RE: clearpass cisco posture
    Posted Sep 05, 2014 09:03 PM
    yes iwa nt each time the user connect to network toc heck if its pc is healthy or not via wired connection on cisco switch,
    i have create a service , inside the service there is a policy, inside the policy there 2 rules
    first rule:
    tips role eq user auth
    & tips role machine auth
    & tips posture eq healthi
     assign cisco Dacl profile1 (radius cisco : cisco ip donwloadable acl : permit ip any any)
    *** here i need to know how to configure second profile for this rule to redirect him to unguard without installing the agent on his pc
    how can i do it?
     second rule:
    & tips posture not eq healthy
    assign cisco Dacl profile2 (radius cisco : cisco ip donwloadable acl : ?)
    here i need to assign profile that redirect a user to ungaurd portal also
    and i need to cach his crednt for the second connection
    how can i do it on clearpass and cisco switch?
    thank you
  • 4.  RE: clearpass cisco posture
    Posted Sep 05, 2014 10:47 PM
    You can do the following :
  • 5.  RE: clearpass cisco posture
    Posted Sep 05, 2014 10:53 PM
    Tthis has three user roles.
    Employee
    Staff
    Student
    Victor is correct. the easiest thing to do is send a acl with the redirect to the CP page.
  • 6.  RE: clearpass cisco posture
    Posted Sep 06, 2014 06:34 AM
    should i add this profile cisco wired onguard with posture profile to the both rules?
    should i create web auth service also?
    url-redirect= is it onguard url  page?
    thank you
  • 7.  RE: clearpass cisco posture
    Posted Sep 06, 2014 06:51 AM
    here the policy and the profiles,,
    is that the right way?
    should i create or add another configuration?
    thank you
  • 8.  RE: clearpass cisco posture
    Posted Sep 06, 2014 09:02 AM
    What type of Agent are you using Persistent or Diss ?
    I think what you should do is send full access VLAN when it meets:
    - Machine Auth
    - User Auth
    - Healthy Posture
    And if the following criteria is:
    - Machine Auth
    - User
    - Not Healthy
    Then you send the Cisco AV Pair with the URL and ACL
    The ACL on your switch should look like this :
    ip access-list extended <ACL NAME>
    deny tcp any host <ClearPass IP Address>
    permit tcp any any
    Make sure that you enable ip http server on your switch
  • 9.  RE: clearpass cisco posture
    Posted Sep 06, 2014 09:12 AM
    hi,
    whenit meets
    user auth
    machin auth
    healthy psoture
    am sending Dacl (ip any any)
    i dont want to use vlan
    am using disov agent
    i have those services
    wirelss service
    web based auth service--->health check service
    wired cisco service
    mac caching service
    is that right ordering way?
    my wireless working good with posture and everything,
  • 10.  RE: clearpass cisco posture
    Posted Sep 06, 2014 06:58 PM
    That looks good
