clearpass cisco voip
This thread has been viewed 16 times
  • 1.  clearpass cisco voip
    Posted Oct 11, 2015 02:35 AM
    hi,
    we have an issue while we are trying to configure cppm with cisco voip on cisco port switch,
    we've created mac auth service, and did all configuration on port for mab and dot1x,
    once we plug the voip its authenticated and authorizde but after 2 minte it keeps try to reauthenticate and reauthorized again and again ,
    how to stop it
    thank you
  • 2.  RE: clearpass cisco voip
    Posted Oct 11, 2015 08:36 PM
    Can you please share the port config and the enforcement profile ?
  • 3.  RE: clearpass cisco voip
    Posted Oct 12, 2015 01:22 AM
    hi,
    aaa new-model
    radius-server host 10.239.16.34 key aruba123
    dot1x system-auth-control
    aaa authentication dot1x default group radius
    aaa authorization network default group radius
    aaa accounting dot1x default start-stop group radius
    aaa server radius dynamic-author
    client 10.239.16.37 server-key aruba123
    port 3799
    auth-type all
    ip dhcp snooping
    ip device tracking
    radius-server vsa send authenticat
    exit
    (config)interface vlan 1
    ip address 10.239.17.38 255.255.252.0
    ip helper-address 10.239.61.18
    ip helper-address 10.239.16.37
    exit
    interface gig 1/0/1
    switchport access vlan 1
    switchport mode access
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    mab
    dot1x pae authenticator
    dot1x timeout server-timeout 30
    dot1x timeout tx-period 10
    dot1x timeout supp-timeout 30
    dot1x max-req 3
    dot1x max-reauth-req 10
    spanning-tree portfast
    lldp transmit
    lldp receive
    exit
    exit
    enforcment prfoule it just vlan assignment
    and
    rasdius:cisco   /  cisco:avpair  /   device-traiffice-class-voice
  • 4.  RE: clearpass cisco voip
    Posted Oct 12, 2015 01:28 AM
    Config looks good. Most common issue is that the phone can not talk to the pbx so it will reboot to try again. Make sure it can route correctly on the vlan.
  • 5.  RE: clearpass cisco voip
    Posted Oct 12, 2015 01:51 AM
    ip phone working fine and getting ip also,
    the problem it doesnt getting right vlan ip from my enforcment profile
    its getting ip from default vlan on the port,
  • 6.  RE: clearpass cisco voip
    Posted Oct 12, 2015 01:55 AM
    Then you need to enable debug on the switch and see if it is getting the correct vlan. If it's getting the default then the void vlan is not in the switch Config or you're enforcement profile is incorrect. Post a screen shot of access tracker and each of the tabs
  • 7.  RE: clearpass cisco voip
    Posted Oct 12, 2015 09:11 AM
    Under the interface do the following:
    switchport voice vlan <VOICE VLAN>
  • 8.  RE: clearpass cisco voip
    Posted Oct 13, 2015 06:19 AM
    we've already added it,
    voip getting ip address, but from default access vlan,its not redirecting to enforcment vlan
  • 9.  RE: clearpass cisco voip
    Posted Oct 15, 2015 07:23 AM
    Hi ,
    I understand that you are only using cisco phone to mac auth with clear pass. You mention 802.1x ..Please elaborate .
    Can you share me the enforcement profile  which you did in clear Pass. I want to verify that if you are sending the correct attributes COA to the cisco switch ?
    Regards
    Khalid Shaikh
    ACCP   ACMA    ACMP   CCIE R&S
  • 10.  RE: clearpass cisco voip
    Posted Oct 16, 2015 04:17 AM
    i solved  it buddy,
    authorization command was missing, and you have to delete switchport voice also, in order to send ur vlan assignment :D
  • 11.  RE: clearpass cisco voip
    Posted Oct 12, 2015 09:07 AM
    Are you sending the voice-vlan ?
