Clearpass CLI
  • 1.  Clearpass CLI
    Posted Apr 25, 2014 05:56 AM
    Hello Airheads,
    what does "lookup static" mean in Clearpass CLI when you run the "network ip list" command?
  • 2.  RE: Clearpass CLI
    Posted Apr 29, 2014 04:36 PM
    I believe those are manual IP table entries.
  • 3.  RE: Clearpass CLI
    Posted Apr 30, 2014 02:41 AM
    thanks Tim,
    Appreciate your reply
    i didn't phrase the question very well.
    On the CLI I have entered a static route which Clearpass accepted.
    If i then type in "network ip list" the next hop is shown up as "lookup static"
    I have no means of looking up static!!
    I have pulled the logs off the controller bu it says the same thing.
    cheers
    Pete
  • 4.  RE: Clearpass CLI
    Posted Apr 30, 2014 05:14 AM
    I'm pretty sure this is just the way Clearpass shows static routes. Can you post the output so we can see?
