Hi!
i know that this subject is quite complicated but if you have knownledge this particular event.
This problem occurs after weekend usually. When computer has been turned off for the weekend.
When they power on computer on monday, it take very long time when computer get network access. It should use EAP-TLS computer certificate for authentication but it try to mac auth first. Like this
And were it get this 30 second timeout for mac auth? We give MEITA PROFILOINTI VLAN 2490 enforcement where timetout is 3600 seconds?
Here is port configuration of the switch
interface 1/1/42
no shutdown
vlan access 1
aaa authentication port-access dot1x authenticator
cached-reauth
cached-reauth-period 60
max-eapol-requests 1
max-retries 1
quiet-period 5
discovery-period 10
enable
aaa authentication port-access mac-auth
enable
loop-protect
exit
Should i add this line to port config
port-access onboarding-method concurrent <enable | disable>
Or is it gonna generate more TIMEOUT problems?
