Clearpass cluster update token invalid
This thread has been viewed 29 times
  • 1.  Clearpass cluster update token invalid
    Posted Aug 11, 2022 05:08 AM
    I have updated our Publisher to 6.10 but now all the subscribers are displaying unknown, invalid, or expired refresh token
    the Generate Token button is greyed out and so i am unable to upgrade the subscribers to the same version as the publisher.
    I have tried the manual upload of the upgrade but this also fails
    any ideas about how to apply the upgrade?
  • 2.  RE: Clearpass cluster update token invalid
    Posted Aug 11, 2022 09:11 AM
    Please manually install 6.10.6 and try again.  6.10.0 does not have the latest CA trust required for token authentication.
  • 3.  RE: Clearpass cluster update token invalid
    Posted Aug 12, 2022 06:03 AM
    ... and to make your life easier, use the cluster upgrade so you only need to upload the image to the publisher and upgrade from there all your subscribers as well.
