last person joined: 9 hours ago
Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
This thread has been viewed 40 times
  • 1.  Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 09:56 AM
    Hello all,
    in order to implement wired guest service, we currently try to initiate a CoA Port Bounce on a HPE Aruba 2930M Stack with WC.16.09.0004 installed. Clearpass is running in Version 6.8.3.110034 on C2000V platform.
    Troubleshooting done so far:
    - Both CPPM and Switch are running NTP.
    - Switchconfig was checked with this guide: http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8152_wb_2920_asg/content/ch06s04.html#s_Configuring_the_switch_to_access_a_RADIUS_server
    - Switch is added as NAD with vendor Hewlett-Packard-Enterprise
    - Standard-CoA-Port 3799 is used
    Switchconfig:
    radius-server host X.12 key XXX
    radius-server host X.12 dyn-authorization
    radius-server host X.12 time-window plus-or-minus-time-window
    radius-server host X.12 time-window 0
    Screenshots:
    Please help, why we are receiving the folling error message when trying to send a CoA:
    Radius [ArubaOS Switching - Bounce Switch Port] failed for client 48XXXfXX. Unsupported-Attribute.
  • 2.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 10:05 AM
    Are you using a VIP in ClearPass?
    Please confirm that the time matches between CPPM and the Switch
    Sent from Mail for Windows 10
  • 3.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 10:28 AM
    Hello Victor,
    thanks for the immediate reply :)
    Actually the times match, because both devices are using NTP to synchronize against our AD-Servers.
    Here some screenshots:
  • 4.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 10:32 AM
    Are you a VIP in ClearPass?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 5.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 12:27 PM
    This is a bug in 6.8.3. A hotfix will be released next week to address this issue.
    A note was added to the download shortly after it was discovered and it is in the release notes: https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.8.3/Default.htm#WhatsNew/KnownThisRls.htm#known_35984
  • 6.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Jun 14, 2024 10:48 AM
    Hi Cappalli,
    Have there been any reports of this issue returning in one of the recent updates? We experience the exact same behaviour in a new deployment where we have installed CPPM 6.12.2.302889 (latest patch). Default ArubaOS CoA (both bounce port and terminate session) to a 2530-8G or 24G fail with "Unsupported Attribute". Tested on multiple switches on different switch firmwares.
    Thx,
    Niels
  • 7.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted 23 days ago
    I have not heard about that. Please open a TAC case, it's possible that there is a configuration issue, rather than a bug.
  • 8.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted 15 days ago
    Hi Herman
    We got around to fixing the issue by updating our AOS switches to the latest firmware, in which the CoA RADIUS response was handled without any issues.
    Niels - Tricore
  • 9.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 12:32 PM
    Hello Victor,
    No - we are not using VIP even though we have a Clearpass-Cluster. This is because we are not L2-Connected between the nodes.
    In the switch there are both CPPM-Nodes configured as radius hosts and we do the failover via the switch logic.
    We are currently doing some Wireshark and we can see, that CPPM is correctly sending the COA but the switch is returning the CoA-NAK:error11.png
  • 10.  RE: Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
    Posted Nov 08, 2019 01:04 PM
    Tim just indicated that there’s a bug in the version you are running
