Clearpass CoA Problem
This thread has been viewed 47 times
  • 1.  Clearpass CoA Problem
    Posted Feb 10, 2014 02:36 PM
    Guys there have been plenty of posts about this - I got issues where I cannot make a CoA from CPPM to a controller - just to disconnect.
    This is for guest at present and using MAC auth.
    I have:
    • Made sure my RFC 3576 Servers are defined with the correct PSKs
    • Associated my RFC 3576 Servers with the right AAA profile
    • Tried to make sure the RADIUS client (aruba MC) is calling in on the right IP Addresses (reference NAS IP addresses)
    • Checked with a AAA debug - just to make sure that my AAA server configrution is correct
    • Made sure routing is OK between devices
    • Checked the MAC addresses are correct on CPPM and controller
    • Clicked on a record under access tracker, then Radius CoA, then change status then [Aruba Terminate Session]
    • Even copied the [Aruba Terminate Session] enforcement profile and modified the copy
    I cannot understand what is failing here.  If the packet contents need to contain the mac address, the radius PSK is correct (as far as I can tell as I do not know debug for this), the routing also good, surely everything is in place to relay the relvant data between the devices for it to act on this disconnect?
    "Failed to contact Access Control Service"
    At a loss.... any help greatfully recieved... faliing that, it'll be a TAC.
    Thanks in advance everyone.
  • 2.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 02:37 PM
    oh yeah - no firewalls or ACLs in between either :smileyfrustrated:
  • 3.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 02:43 PM
    Couple things
    1. Check the application log in CPGuest side to see if there are any errors.
    2. Ive seen issues if you dont have add ip in the redirect.
  • 4.  RE: Clearpass CoA Problem
    Posted Mar 05, 2014 09:08 AM
    Excellent..I was have a same problem..With "add switch ip in the url" option solves everything !!
  • 5.  RE: Clearpass CoA Problem
    Posted Feb 11, 2015 02:03 AM
    sorry for bumping this thread back alive.
    i'm having same problem you guys explained in this thread but my CoA still not working with error exactly the same with Nik.
  • 6.  RE: Clearpass CoA Problem
    Posted Feb 15, 2015 07:48 AM
    i would advise you to start your own thread. even though your error is the same your setup probably isn't.
    so new thread, explain your full setup: controller(s), clearpass, services and what exactly you try.
  • 7.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 02:44 PM
    Maybe a packet-capture on the controller might shed some light on this issue:
    Via CLI, not in configure mode:
    packet-capture controlpath udp 3799
    packet-capture destination local-filesystem
    You can get the PCAP if you pull a logs.tar from the controller.
  • 8.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:09 PM
    OK, so I did not have the "Add switch IP address in the redirection URL" - so that is ticked - I see the logic there, and I should have had that on, I have a multicontroller environment,
    However no difference is seen. same error on CPPM "failed to connect to ACS device"
    On the other hand I did take a pcap - useful tip there arjan thanks - and I do see the CoA packet come in  - 6 in fact and 2 reporting to be duplicates.  Presumaly "3 tries and your out" kind of attempts.  I see the right MAC address in the packet too - but is is represented in upper case with no delimeters between octects in the mac address.
    I did see the CoA call in with a datapath session table command before, but not to this detail - it is reassuring the mac is right in the packet payload as well the source and destination.
    Thank you both for your help - is there any way to determine - out of sheer paranoia that the psks in the rfc3576 is ok?
    I can't help thinking I have misssed something basic here.  I have used amigopod before but never had this problem.
  • 9.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:10 PM
    sorry should say "failed to contact access control service"
  • 10.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:18 PM
    You can see the PSK's via the CLI:
    encrypt disable
    show aaa rfc-3576-server 1.1.1.1
    Do you have any firewall policies active on the controller that might block outgoing traffic from the controller? Either on the physical interface or using the "firewall-cp"-feature (added in ArubaOS 6.3)
  • 11.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:20 PM
    Do you have RADIUS CoA ticked in NAD configuration in ClearPass?
  • 12.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:29 PM
    Hi tim,
    yes, that's ticked - I found when it was not ticked I found the CoA radio button was greyed out
    but yes thats all there thanks.
    really appreaciate all this help chaps
  • 13.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:46 PM
    Can you please check the following ?
    Show IP radius source interface
    Show IP radius nas IP
    What do you have set for your controller ip ? Loopback , VLAN or vrrp IP ?
  • 14.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 05:05 PM
    (ldnwcmc1) #Show IP radius source-interface
    Global radius client source IP address = 172.29.234.6, vlan 200
    Global radius client source IPv6 address = ::, vlan 0
    Per-server client source IPv4/6 addresses:
    (ldnwcmc1) #Show IP radius nas-ip
    RADIUS client NAS IP address = 172.29.234.5
    RADIUS client NAS IPv6 address = ::1
    (ldnwcmc1) #
  • 15.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 09:16 PM
    Make sure that both of those values match and also that you have the same value on your CPPM server
  • 16.  RE: Clearpass CoA Problem
    Posted Feb 11, 2014 03:01 AM
    Thanks victor,
    I have changed these values now they match
    I am opening a TAC.
  • 17.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:27 PM
    Arjan - yes of course - I decrypted the psks but they do seem to be in good order and correct
    I do not have FW policies applied - all interfaces are trusted and I did look at the - i guess- control plane FW policy
    When I grep it for 3799 I see acl hits on a permit for udp (I truncated the output below) - not sure if relevant?
    ldnwcmc1) #show firewall-cp internal
    CP firewall policies
    IP Version  Source IP  Source Mask  Protocol  Start Port  End Port  Permit/Deny  hits  contract
    ipv4        any                     17        3799        3799      Permit       116
    ipv6        any                     17        3799        3799      Permit       0
  • 18.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 03:19 PM
    Checked the app logs on CPGuest
    They make reference to what looks like the same error, but represented in a php call into CPPM using the same default enforcement profile as I am using in CPPM:
    disconnecting the session
    Client:    10.11.160.56:64790
    App User:  sheridannet
    Script:    /guest/guest_sessions.php
    Function:  NwaGuestManager_GuestSessions_Disconnect
    Arguments: array (
      'error' => 1,
      'message' => '{"content": {"cnc_actions": [{"status_message": "Radius [Aruba Terminate Session] failed for client 406f2a3738d5", "id": 1}]}, "id": "R000001fa-04-52f92f9d", "name": "cnc_response"}',
  • 19.  RE: Clearpass CoA Problem
    Posted Feb 10, 2014 04:57 PM
    Hi sorry I am on an awkward time zone. I am using avrrp address and will provide output from the command tomorrow uk time.
    Thanks again all
  • 20.  RE: Clearpass CoA Problem
    Posted Feb 11, 2014 07:59 AM
    I have made a grave mistake here and as a punishment I will post a diagram of my configuration with all the great feedback I got from all you good folks!!!!!
    We are now working!!!!
  • 21.  RE: Clearpass CoA Problem
    Posted Feb 19, 2014 01:49 PM
    Hi Nok,
    Could  you please post what you did to make thingsh happy?
    Mike
  • 22.  RE: Clearpass CoA Problem
    Posted Feb 19, 2014 01:50 PM
    sorry, I meant "Nik" !!
    Mike
  • 23.  RE: Clearpass CoA Problem
    Posted Feb 21, 2014 01:58 AM
    After all that digging about I had changed the IP address of the rfc3576 servers several times in deployment and I had entered the wrong IP addresses under the rfc3576 servers. I got totally lost in details. Yes I am an idiot. I will post up a diag too as promised. I was hoping no one would press me for an answer. ;). As soon as I got someone else to look at it with a fresh pair of eyes they spotted it immediately. I laughed as there was little else I could do. ;) well I suppose I could have cried also?
  • 24.  RE: Clearpass CoA Problem
    Posted Feb 21, 2014 02:01 AM
    I would also say that the matter if source IP addresses in radius was especially relevant as the source IP address as explained above is unique to the controller even when in a master local deployment like mine - and this was also key in getting this problem straightened out.
