Clearpass configuration
This thread has been viewed 51 times
  • 1.  Clearpass configuration
    Posted Mar 24, 2024 01:35 PM
    Hi All,
    Working on a clearpass wired 802.1x deployment and have some configurations on some configuration best practices.  In the deployment, the network devices are cisco.
    I noticed in the template from the vendor, they are logging to clearpass over udp port 20514.   The below command from the config.  I'm familiar with this config/port when using Cisco ISE, but not sure if this is correct for clearpass.  My question is it best practice to send syslog from the NAD (switch) to clearpass and is this the proper port?  I can't find it in the config.
    logging host <clearpass IP>  transport udp port 20514
  • 2.  RE: Clearpass configuration
    Posted Mar 25, 2024 10:33 AM
    Logging from network devices (like switches) to ClearPass can be beneficial for monitoring and auditing purposes. The UDP port 20514 is commonly used for this purpose, as it allows ClearPass to receive syslog messages from the network devices. It's indeed a standard practice to configure syslog forwarding from network devices to ClearPass, especially for monitoring network access and troubleshooting issues.
    Regarding the specific command you provided:
    This command seems appropriate for Cisco devices to send syslog messages to ClearPass over UDP port 20514. However, it's crucial to ensure that ClearPass is configured to listen on the specified port for syslog messages.
    You may want to double-check the ClearPass configuration to verify that it is indeed configured to receive syslog messages over UDP port 20514. If not, you may need to adjust the ClearPass configuration accordingly.
  • 3.  RE: Clearpass configuration
    Posted Mar 25, 2024 11:00 AM
    @Smit Bret
    Thank you for your response.  Where is this configured in Clearpass?
    Typically, syslog defaults to udp 514
  • 4.  RE: Clearpass configuration
    Posted Mar 25, 2024 03:28 PM
    Unless you are setting up Ingress Events, there is zero reason to ever send syslog to ClearPass.
    https://www.arubanetworks.com/techdocs/ClearPass/6.11/PolicyManager/Content/CPPM_UserGuide/Ingress%20Events/Intro_threat_events.htm
    Was someone under the impression they were trying to implement NetFlow of sFlow with that setup?
    https://www.arubanetworks.com/techdocs/ClearPass/6.11/PolicyManager/Content/CPPM_UserGuide/PolicyProfile/Collectors.htm
    Carson Hulcher, ACEX#110
  • 5.  RE: Clearpass configuration
    Posted Mar 25, 2024 03:57 PM
    Hi @chulcher,
    I don't think they were under the impression they were setting up netflow.  I think it's the case of a partner taking config for one vendor/product (Cisco ISE) and using that same config for clearpass.   I will remove the syslog configuration.   Ingress events may be something to look into, but that seems it would be syslog provided by our firewall, not network switch?
  • 6.  RE: Clearpass configuration
    Posted Mar 25, 2024 04:24 PM
    That is probably correct.  Ingress events would be useful from any device or application that is determining a security stance that you'd want to take action on, firewalls being a potential source.
