In addition to the suggestion to start with passive profiling (DHCP, etc) first, I would in such a case enable MAC authentication, then create a service with [Allow All MAC], and Endpoint Repository as the authentication source.
For getting the most out if visibility, your Aruba partner can get a guide on Arubapedia for Partners (Search for: ClearPass Visibility), which is fully focused on visibility without authentication.
Original Message:
Sent: Aug 23, 2024 08:19 AM
Subject: ClearPass - Configuration for device visibility
Hi community,
I want to configure a service in ClearPass to have visibility all the devices my customer has. I don't want to authenticate them right now, only just seeing what he has, and then, I will create other service for block unauthorized devices. Because many of them are printers, phones, etc. and don't authenticate, I don't know what to put for Authentication Methods, Authentication Sources and Authorization Source, since they are mandatory fields. I have just tested with Authentication Source = [Local User Repository] and Authorization Source = [Endpoints Repository]. With this, ClearPass rejects and show this:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/37f4b312104d406787921d940720a467.png)
Any idea?
Julian
