ClearPass CRL error: Different CRL Scope
This thread has been viewed 21 times
  • 1.  ClearPass CRL error: Different CRL Scope
    Posted Feb 03, 2020 07:07 AM
    Hi Community,
    a customer is faceing an issue with CRLs in ClearPass. He has an offline Root-CA and an online Sub-CA on microsoft server. Certificate based LAN auth is working fine until you load the crls into clearpass. There is an error in the logs:
    verify error:num=44:Different CRL scope
    I found some sources stating that the DP entry in the Cert and the IDP entry in the crl must match. I verified that both URLs are the same.
    Any clue how to fix this?
  • 2.  RE: ClearPass CRL error: Different CRL Scope
    Posted Sep 25, 2023 09:56 AM
    Hi. I got a similar problem. Did you find out what the problem was and solved the problem?<o:p></o:p>
    <o:p> </o:p>
  • 3.  RE: ClearPass CRL error: Different CRL Scope
    Posted Oct 16, 2023 11:45 PM
    Any solutions here also have the same problem that just started after the Enterprise CA setup was migrated to MS Server 2019.
