Clearpass Crowdstrike API
This thread has been viewed 30 times
  • 1.  Clearpass Crowdstrike API
    Posted Oct 16, 2020 04:36 AM
    Hello, i would like to setup an API connect between Clearpass and Crowdstrike. The idea is to use Crowdstrie as an authorization source.
    I had a look in the ClearPass_Integration-Guide_Crowdstrike_Flacon.pdf.
    Unfortunately i always get the following error message:
    [2020-10-16T07:54:50.581] [ERROR] CrowdStrike - Protocol "http:" not supported. Expected "https:"
    [2020-10-16T07:54:50.583] [ERROR] CrowdStrike - Protocol "http:" not supported. Expected "https:"
    For me it looks that the Clearpass is sende the request with HTTP but i don`t know where to change it.
    Does someone maybe have an idea?
    Stefan
  • 2.  RE: Clearpass Crowdstrike API
    Posted Oct 16, 2020 03:18 PM
    Hey Stephan,
    Can you set the debugging level in the extension to DEBUG from the default of INFO.
    Restart the extension and send me the entire log please.... to jump@hpe.com
  • 3.  RE: Clearpass Crowdstrike API
    Posted Oct 23, 2020 06:51 PM
    Any progress on resolving this?
