Is it possible to use the ClearPass dataport with a network adapter which is configured within vmware in trunk mode (All VLAN IDs 4095)?
Many thanks in advance.
Poking around, it sure looks like you can - in the Server Configuration panel, look onthe Network tab and you will find VLANs and the ability to create them per interface.
