In Access Tracker, press: Change Status:
From there select the CoA method for your client.
If that doesn't work, you can probably also disconnect the client from the AP/switch/controller/Central/management platform, to let it reconnect and re-authenticate.
Original Message:
Sent: Jan 29, 2024 02:06 PM
Subject: Clearpass deauth client
I couldnt find how to deauthenticate a user/endpoint to force them to re authenticate
