Clearpass: Determine which HD I'm booted from
  • 1.  Clearpass: Determine which HD I'm booted from
    Posted Feb 19, 2014 11:51 AM
    I'm running Clearpass 6.2 (exact version below, but 25k version).  I have three Harddrives, SCSI 0:0, 0:1 and 0:2, where 1 and 2 are 500gig.  The upgrade to 6.3 says I need to add a new 1024gig disk and remove the 'inactive' one.  How do I determine which is the inactive disk without rebooting?  (want to minimize downtime)
    From the CLI I can enter:
    # system boot-image -l
    ClearPass Platform 6.1.0.50820
    Aruba ClearPass 6.2.0.54353 [Active]
    I could jump to the conclusion that these are ordered and 0:1 is CP 6.1 and 0:2 is the active 6.2.  But I'd like to be sure before I remove it.  I'd also love to verify that my newly added disk is recognized after I reboot in order to discover it.  Any way to do that?  Not seeing the option in the GUI or CLI.  (I wish I had a real shell! :)
    #6.3
    #6.2
  • 2.  RE: Clearpass: Determine which HD I'm booted from
  • 3.  RE: Clearpass: Determine which HD I'm booted from
    Posted Feb 19, 2014 02:09 PM
    Ah, I see on the second page.  I didn't see that when I first browsed that thread.  This is the relevant bits that dannyjump posted:
    Figuring out which disk is active v inactive, the best way is to use the vSphere/vCenter tools...in vSphere.....
    Go to the monitoring page and click on performance. There will be a drop-down list on the RHS of the screen....'Switch to:' Select virtual disk......if you only see a single disk....go to chart options and ensure all disk are selected under 'Objects'.......
    You should see either disk one (scsi 0:1)  or two (scsi 0:2) with activity.  The one that does not have any activity can be deleted and then re-added, ensure you double the size of this disk from its previous size.
    This makes total sense.  In vSphere I do see a disk with 0 activity and one with a bunch.  However, I suspect because of how I added the disks, the two disks show up as the same iSCSI Device target.  I thought to check vSphere's (I've got 5.1) datastore to see which vmdk file wast modified but that doesn't help either (modified date was 4 days ago on both the vmdk files).
    I suppose I may have to suck it up and reboot to see.
  • 4.  RE: Clearpass: Determine which HD I'm booted from
    Posted Feb 19, 2014 02:12 PM
    Ok, posted too quickly again.  I found it under "Virtual Disk":
