ClearPass Device Insight Data Collector - Default Login ?
This thread has been viewed 16 times
  • 1.  ClearPass Device Insight Data Collector - Default Login ?
    Posted Jan 20, 2020 08:14 AM
    I am currently testing ClearPass Device Insight.
    A virtual Data Colelctor is available via Central.
    It is based on Ubuntu.
    Unfortunately the default login is not documented anywhere, neither in the online help nor anywhere else.
    There is also no information about the Hardware Collector.
    Can anyone here help me?
    Tank you :)
  • 2.  RE: ClearPass Device Insight Data Collector - Default Login ?
  • 3.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jan 20, 2020 08:41 AM
    yeah I did.
    But there is no default Login mentioned.
    Maybe the documentation is for an older version of the virtual appliance ?
    The Login comes right after the vm has booted up.
    There is no initial config dialog, like it is mentioned here:
    https://www.arubanetworks.com/techdocs/ClearPassDeviceInsight/1.0/content/online_help/getting_started/settingupvirtapphostwebclient.htm
    There is just the Ubuntu tty Login...
  • 4.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jan 20, 2020 09:04 AM
    Ok, it is taking you to login prompt instead of config option in CLI? Did you try admin/eTIPS123 credentails?
  • 5.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jan 20, 2020 09:08 AM
    Yes, youre right.
    I tried several "standard" default combinations like admin/admin
    admin/blank password an so on.
    And now also admin/eTIPS123....they all did not work...
  • 6.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jan 20, 2020 09:15 AM
    Below default credentials should work both for hardware and VM.
    Username = aruba
    Password = aruba
    This detail already there in link which I shared
    https://www.arubanetworks.com/techdocs/ClearPassDeviceInsight/1.0/content/online_help/getting_started/settingupphysicalapplianceprocflow.htm
  • 7.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jan 20, 2020 09:17 AM
    That worked !
    Thank you very much
  • 8.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jul 06, 2020 07:36 AM
    Where do you find the virtual collector?
  • 9.  RE: ClearPass Device Insight Data Collector - Default Login ?
    Posted Jul 06, 2020 09:22 AM
    Just need to login into your Central account and click on the Data Collectors link and you will have the option to download the CDI OVA
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
