Clearpass - Discovered Devices to Network Devices
  • 1.  Clearpass - Discovered Devices to Network Devices
    Posted Jul 17, 2018 10:15 AM
    I would like to make all of my network switches, network devices in Clearpass.
    Is there a way to make a discovered device a network device or will I need to manually add them?
  • 2.  RE: Clearpass - Discovered Devices to Network Devices
    Posted Jul 17, 2018 10:42 AM
    With discoverd device you mean endpoint?
    What you can do is export 1 device (not endpoint), add every switch in the xml, and re-import the complete xml with all switches.
    Other option is to add a device with a subnet, this way you have 1 entry for a complete /24 management subnet, you must use the same radius/tacacs keys, and you cannot filter on source device or specific attributes for a device (only nas-ip).
  • 3.  RE: Clearpass - Discovered Devices to Network Devices
    Posted Jul 17, 2018 11:43 AM
    At one point I ran the Network Scan, under Profile and Network Scan.
    It discovered most of my switches and they are now listed under Discovered Devices, under the Profile and Network Scan.
    I thought about doing an export/import from the Network/Devices page, but I have yet to find a decent XML editor that will work. I could do it manually using Notepad, but that's a pain.
