Are there any documentation available for using SQL server with Clearpass? User guide shows where to put the database name and credentials, but how about what does the Clearpass query from the server? And how it expect the data to be formatted, and in which fields?
For example it seems that the user password must be returned as "user_password" but where is this documented?
ClearPass will use SQL to extract data from the SQL server.
An example:
SELECT mac from MACADDRESSES
mac being the column and MACADDRESSES being the table.
You will need to construct your select statement to get the data that you are after.
