ClearPass EAP-TLS 1.2 support
  • 1.  ClearPass EAP-TLS 1.2 support
    Posted Feb 23, 2015 06:29 PM
    Does ClearPass support TLS 1.2 for EAP?
    If so how do you enable it?
    I have updated by Windows clients to allow negotiation of TLS 1.2 but CPPM still sends back server hello with 1.0.  (6.4.x)
    Scott
  • 2.  RE: ClearPass EAP-TLS 1.2 support
    Posted Feb 24, 2015 01:45 AM
    Not today. There has not be a big call for it. I would file a feature request if its something you must have.
  • 3.  RE: ClearPass EAP-TLS 1.2 support
    Posted Feb 24, 2015 04:27 PM
    Thanks Troy, will do.
  • 4.  RE: ClearPass EAP-TLS 1.2 support
    Posted Mar 03, 2015 05:05 PM
    Hi All, TAC has confirmed that support for TLS version 1.2 is added in CPPM version 6.5.1. The reference bug/feature request number is # 28012.
  • 5.  RE: ClearPass EAP-TLS 1.2 support
    Posted Jun 24, 2015 10:08 AM
    Was having a similar issue. Confirmed with TAC that TLS 1.2 is NOT supported in 6.5.1 but is in 6.5.2 which is due out shortly.
  • 6.  RE: ClearPass EAP-TLS 1.2 support
    Posted Jun 27, 2015 11:11 AM
    6.5.2
    ClearPass now supports TLS version 1.2 in addition to 1.0 and 1.1 in TLS-based EAP methods. (#28012)
  • 7.  RE: ClearPass EAP-TLS 1.2 support
    Posted May 27, 2016 01:30 PM
    Hi Tim,
    If the client supports all three EAP-TLS versions, which one is going to used? Does ClearPass enforece the highest possible?
