ClearPass Endpoint Profiling not working
This thread has been viewed 59 times
  • 1.  ClearPass Endpoint Profiling not working
    Posted Mar 16, 2021 07:12 AM
    Hi everybody,
    i am not able to enable endpoint profiling in my CPPM. I have created a MAC-based authentication service with the following enforcement:
    On my switch (HP 2530-8G-PoEP Switch (J9774A)) I´ve added the CPPM as IP helper on all VLANs. The device is redirected to VLAN401, but not profiled.
    Any recommandations?
    Kind regards,
    Matthias
    Matthias Pohl
  • 2.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 16, 2021 09:45 AM
    Do you have look if the CPPM receive the DHCP packet ?
    Why use IP Helper on the 2530 ? i think it is not the default gateway of the vlan ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 16, 2021 10:12 AM
    How can I check if the CPPM receive the DHCP packet?
    That was my understanding, to add the IP Helper on the 2530, so that the DHCP packet also get´s redirected to the CPPM, to be able to perform the profiling
    Matthias Pohl
  • 4.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 16, 2021 10:15 AM
    the 2530 have IP Address on each vlan ?
    You can make a packet capture on CPPM
  • 5.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 16, 2021 11:19 AM
    Hm, I´m not an expert, but to me it looks like, if CPPM doesn´t receive the DHCP packet
    Matthias Pohl
  • 6.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 16, 2021 03:59 PM
    You need to found why...
    the switch can reach the CPPM ?
  • 7.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 17, 2021 03:19 AM
    Yes, the switch can reach the CPPM.
    In the access tracker I can see, that the right service is picked. The device is assigned into the right VLAN and gets an IP address assigned. This is working fine. But, the device is not profiled.
    Matthias Pohl
  • 8.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 17, 2021 04:15 PM
    What the gateway of this vlan ? do you have look to use DHCP relay on this vlan ?
    how to the device get the IP Address ?
  • 9.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 22, 2021 04:57 AM
    Hi, sorry for the late response.
    This is our test environement:
    If the device is not profiled it comes into the VLAN401.
    In VLAN401 i´ve configured the CPPM as IPHelper. The DHCP server is configured on the firewall.
    GW is 10.20.252.1
    I´ll check with our firewall guy, if our routing is configured correctly.
    Matthias Pohl
  • 10.  RE: ClearPass Endpoint Profiling not working
    Posted Mar 26, 2021 03:52 AM
    Ok, it was a GW problem. On Aruba 2530 you can´t define a GW per VLAN.
    We´ve changed the routing and now everything is working fine.
    Thx for you support Alagoutte
    Matthias Pohl
  • 11.  RE: ClearPass Endpoint Profiling not working
    Posted Apr 07, 2021 12:48 PM
    Sometimes DHCP fingerprinting only gets you so much information.  The browser agent information is not transferred in the fingerprint.  It looks like it could only tell that it is a Windows computer from the fingerprint.  If you configured if-map, the browser agent information would be transferred to CPPM without the fingerprint.  Configure IF-MAP, delete the endpoint and see if works.
    Rector Rios
