Network Management
Clearpass enterprise Ssid with Eap-Tls
  • 1.  Clearpass enterprise Ssid with Eap-Tls
    Posted Jun 03, 2023 04:48 PM
    We are trying to use Peap/ Eap-Tls authentication for the enterprise ssid. I was sugested by a CP engineer to use eap/ Eap-Tls and push the cert to the serverer as well as the client devices. He did not give specification on the type of cert I need. Can we use a self signed CA cert on a production environment? We have multiple devices that would connect to the enterprise Ssid. We intended to push the cert on domain joined devices using a group policy. Or should we buy a public root CA? Appreciate the help.
  • 2.  RE: Clearpass enterprise Ssid with Eap-Tls
    MVP EXPERT
    Posted Jun 05, 2023 08:46 AM
    Take a look at the Certificates 101 Tech Note its a little dated but still perfectly valid for an EAP-TLS deployment. Generally, if you have control over the devices (such as corporate devices) then an internal CA/PKI is perfectly valid.
  • 3.  RE: Clearpass enterprise Ssid with Eap-Tls
    Posted Jun 05, 2023 10:23 AM
    The minimum you would need:
    • The client has a client certificate with the client authentication purpose
    • The ClearPass server has a server certificate for server authentication with the server authentication purpose (it can be an SSL cert, quite frankly).
    • The Clearpass Server has the CA cert for the CA that issues the client certificate imported in the ClearPass Trusted Certificate Authorities list
    • The Clearpass Server has the CA cert for the CA that issued its own server certificate imported into the ClearPass Trusted Certificate Authorities list
    • The Client has the CA cert for the CA that issues the ClearPass certificate's server certificate
    In Clearpass if you use the EAP-TLS authentication method with everything unchecked, the 5 items in place on top should work.
