ClearPass Entry - New license
This thread has been viewed 41 times
  • 1.  ClearPass Entry - New license
    Posted Mar 06, 2019 05:44 AM
    Hi all
    Just noticed a new ClearPass license SKU in Iris….Whats ClearPass Entry? Im guessing a cutdown access license?
  • 2.  RE: ClearPass Entry - New license
    Posted Mar 06, 2019 06:03 AM
    Please contact your local Aruba SE for details.
    Product is not official launched now, but soon...
  • 3.  RE: ClearPass Entry - New license
    Posted May 03, 2019 01:36 PM
    Hello i am SE to CentroAmerica but i can help with more details , if is necessary i can joint the SE for your region. My email is eae@hpe.com can contact me
  • 4.  RE: ClearPass Entry - New license
    MVP EXPERT
    Posted May 04, 2019 04:09 AM
    See https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.8.0/Content/WhatsNew/NewFeatures_Licensing.htm
    The entry license is “access” license without tacacs and profiling. After purchase a entry license upgradepath to access license is possible.
    But most case i would recommende the normal access license.
  • 5.  RE: ClearPass Entry - New license
    Posted May 04, 2019 05:09 PM
    Entry also does not include any 3rd party integrations.
  • 6.  RE: ClearPass Entry - New license
    Posted May 04, 2019 04:13 AM
  • 7.  RE: ClearPass Entry - New license
    Posted May 06, 2020 12:43 PM
    Entry Licenses An Entry license is a basic application license that supports a limited number of core features, including:
    * 802.1X Authentication
    * MAC authentication
    * Web-based user registration and authentication (such as self-registration, sponsor based, and social)
    * Multi-Factor Authentication
    * OnConnect
    * Some 360 Security Exchange features, including local Endpoint Context Servers and Context Server Actions for localhost, and XML/REST APIs, Entry licenses are available as permanent or evaluation licenses. This license does not support Network Scan features.
    If your deployment does not include an Access License, the network scan features are disabled and the span port cannot be changed from its default value. the Entry license does not include support for the TACACS+ authentication and endpoint profiling features supported by the Access license. Entry licenses also do not support non-Local host endpoint context servers or ClearPass extensions.
  • 8.  RE: ClearPass Entry - New license
    Posted May 07, 2020 12:42 PM
    Dinusha - Was there a question from your post?
  • 9.  RE: ClearPass Entry - New license
    Posted May 08, 2020 01:25 AM
    Nope, my apologies
  • 10.  RE: ClearPass Entry - New license
    Posted Mar 08, 2021 11:26 AM
    Hallo Dinusha,
    Quick question please.
    If a customer has rolled out Certificates on all of his endpoints and wants to use ClearPass Entry to select which VLAN the endpoint should be placed in, will this work or do I need the profiling feature from Access for this?
    Thank you.
    Paul
    Paul Wade
  • 11.  RE: ClearPass Entry - New license
    Posted Mar 08, 2021 12:57 PM
    Paul,
    Your basically asking if CPPM can perform EAP-TLS authN/authZ to provide vlan/role based derivation... Yes, basic feature.... I assume certs are deployed say via GPO and a seperate CA/PKI... i.e. you don't want to use CPPM as the CA and CPPM will not be used in processing of CSR to create device-certs {any of this needs Onboard licenses} but if its just processing the authN/authZ your good with an entry level license.
    Danny Jump
    "Passionate about CPPM"
  • 12.  RE: ClearPass Entry - New license
    Posted Mar 08, 2021 02:22 PM
    Great. Thank you Danny.
    Paul Wade
