I think to remember that there was an issue with extension downloads not honoring the proxy settings, but could not find it in the release notes. Please make sure to be on the latest ClearPass hotfix level for 6.11 or 6.12.
Further, some extensions are now posted to the support portal, so that may be a workaround for you as well. If nothing works, please report to TAC as they should be aware of such issues, if there are any.
Original Message:
Sent: Aug 22, 2024 08:41 PM
Subject: Clearpass Extension Installation
Hi All,
I am having issue with Extension installation on Clearpass. Due to the security restriction of environment, all web traffic needs to go via a proxy server. HTTP proxy is enabled as per below but it seems that Extension downloading traffic ignored this Proxy setting and it always bypassed proxy and went to Internet directly, which was ended up with Server Error 500. I am wondering if anyone experienced the same issue and any solution to resolve this. Many Thanks.
