Good afternoon all!
I've hit a brick wall with a clearpass installation i am working on. I'm attempting to install an extension from the store and i keep receiving the error "Error creating extension instance: store lookup failed"
The funny thing is im able to see what stores are available, so i tried a few different stores and get the same issue. Ive confirmed no proxy is blocking access etc.
has anyone else run into this before? i had a good search through the airheads forum and couldnt find anything relevant
Out of curiosity can you confirm version of CPPM in use?
Are you trying to install from the API-Explorer or from the GUI under Guest?
Please try restarting the extension-service and see if that helps.
