ClearPass External HTTP Source - Authentication
This thread has been viewed 21 times
  • 1.  ClearPass External HTTP Source - Authentication
    Posted Feb 19, 2017 07:21 AM
    I'd like to use Clearpass authenticating users using an external HTTP API.
    So it seems possible use a external "http source" as authentication source.
    It isn't so well documented, but it seems that fits my needs.
    When I try to use this custom source into a Service profile (radius) I've got :
    "HTTP type Authentication Source is not supported for RADIUS services"
    But if it isn't possible to use a HTTP source for Radius authentication, it seems pretty useless ... 99,99% of authentication comes from controller or VirtualController (Arubanetworks) or other devices that can talk only Radius for authentication.
    How can I authenticate users provvisioned into external system that exports REST API?
    Regards
  • 2.  RE: ClearPass External HTTP Source - Authentication
    Posted Feb 19, 2017 09:54 AM
    It's really an authorization source, not authentication.
  • 3.  RE: ClearPass External HTTP Source - Authentication
  • 4.  RE: ClearPass External HTTP Source - Authentication
    Posted Feb 22, 2017 04:27 AM
    Thank you Tim,
    Do you think there's any "workaround" to manage this scenario?
    Authentication using external services is becoming a pretty common scenario. Usually all backends are moving from exposing SQL database structure, to a REST/API interface (middleware).
    In fact, it seems that Arubanetworks is developing more and more interfaces for external authentication backend (SAML / Okta / etc) but a present time any other customer's "custom" backend is impossible to integrate with.
     Regards
  • 5.  RE: ClearPass External HTTP Source - Authentication
    Posted Feb 22, 2017 07:16 AM
    Most modern authentication is handled via OAuth2 or SAMl, not direct REST calls. Most scenarios we come across leverage REST calls for authorization.
    If you have a specific use case, please submit an RFE.
  • 6.  RE: ClearPass External HTTP Source - Authentication
  • 7.  RE: ClearPass External HTTP Source - Authentication
    Posted Feb 22, 2017 07:44 AM
    I agree with you that SAML and OAuth can be a good solution.
    They are more secure, standard, well documented...
    But IMHO I think that they are acceptable for  enterprise authentication (employee) or if you want to interact with external authentication services that are outside your network borders.
    I'm talking about a easier use case.  A guest captive portal that needs authenticate user on an internal backend, without using Clearpass provisioning workflow.
    It this case, I think, that overload that comes from SAML (use bouncing between different page) or OAuth is absolutelly unwanted and unecessary.
    I think that it could be  problems with Apple CNA or Android CNA.
    In any case, I agree with you... Best choice for me is open a RFE, but on latest documentation HTTP is already mentioned as authentication source (not authorization) so I should be better open a Bug fix request ;-)
    I'm kidding. ;-)
