ClearPass failed to join the domain
  • 1.  ClearPass failed to join the domain
    Posted Jan 10, 2018 09:16 AM
    I've tryed a lot but i cant connect my clearpass to my domain, the FQDN is correct and username and password are also correct but i recived follow message:
    Adding host to AD domain...
    INFO - Fetched REALM 'CPASS.TESTDOMAIN.COM' from domain FQDN
    'cpass.testdomain.com'
    INFO - Fetched the NETBIOS name 'CPASS'
    INFO - Creating domain directories for 'CPASS'
    INFO - Using Administrator as the CPASS's username
    Enter Administrator's password:
    kinit succeeded but ads_sasl_spnego_krb5_bind failed: Unspecified GSS
    failure. Minor code may provide more information : Server not found in Kerberos database
    Failed to join domain: failed to connect to AD: Unspecified GSS
    INFO - Restoring smb configuration
    INFO - Restoring krb5 configuration file
    INFO - Deleting domain directories for 'CPASS'
    ERROR - ClearPass failed to join the domain CPASS.TESTDOMAIN.COM with
    domain controller as cpass.testdomain.com
    Join domain failed
    The Clearpass-server has a static IP (as he shuld) and is knowen to the domain
    best greads
    Max
  • 2.  RE: ClearPass failed to join the domain
  • 3.  RE: ClearPass failed to join the domain
    Posted Jan 10, 2018 09:30 AM
    thank you, I've sean it bevor but it wasent helpfull... i've made nslookup from clerpass to the domain and it works fine and the DC and the Clearpass-server are in the same subnet so the DC kann see him. But it still dose not worke
  • 4.  RE: ClearPass failed to join the domain
    Posted Jan 10, 2018 09:36 AM
    Please work with Aruba TAC.
  • 5.  RE: ClearPass failed to join the domain
    Posted Jan 17, 2018 04:44 PM
    Is there a firewall between you Clearpass and the AD? I had to create new rules on the windows firewall for LADP ports that Clearpass use to join to AD. Also check the time on both servers clearpass and AD.
  • 6.  RE: ClearPass failed to join the domain
    Posted Jan 19, 2018 02:21 AM
    thank you all for the support i solved the Problem ... it was just stupidity of my. It turned out that i forget to name the DC so he had the domain but nothing else.
    sorry for costing you such trubble
