Clearpass failure
  • 1.  Clearpass failure
    Posted Feb 15, 2017 10:02 AM
    We  will be implening Aruba solution with a pair of 7205 controllers and another with IAP Virtual Controller and  a single Clearpass server.
    There will be 3 SSIDs with: 1.Captive portal guest authentication, 2.AD Credentials authentication and 3.Client-Server Certificate authentication.
    What will be the controllers behaviour if the ClearPass connection is lost? How long will the users stay authenticated in each of the 3 options.
  • 2.  RE: Clearpass failure
    Posted Feb 15, 2017 11:29 AM
    The user will be able to still have access until the next wireless roaming event for the mac auth / open SSID
    On the IAP you can enable authentication survivability for the PEAP / 802.1x SSID
    https://community.arubanetworks.com/t5/Controller-less-WLANs/What-is-Authentication-Survivability-in-IAP-and-how-to-configure/ta-p/178842
    But this option only exist on the ArubaOS controller if you are running a 7000 controller as a branch controller and using EAP-TLS
    http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Branch%20Office/Branch_Deploy_features.htm#Authenti
    Do you have a clearpass cluster ?
    Get Outlook for iOS
  • 3.  RE: Clearpass failure
    Posted Feb 17, 2017 04:10 AM
    Thank you for the below. It is standalone ClearPass Server.
    Looking at the Authentication survivability, it seems quite restricted and probably will not help.
  • 4.  RE: Clearpass failure
    Get Outlook for iOS
