Clearpass Fingerprinting - custom categories, and rules?
  • 1.  Clearpass Fingerprinting - custom categories, and rules?
    Posted Mar 08, 2017 11:29 AM
    Wondered if its possible to define your own custom values to assign to fingerprint rules?  The predefinied list doesnt really identify alot of our devices, which I understand is probably impossible, but surely this should then allow for admins to define their own device categories?
    Im also finding that a rule I have created isnt being applied to new devices, but I cant see where the rule I created is to manage it or check it?  Is this just created and applied at the time you do it, and then doesnt apply to any future devices?
  • 2.  RE: Clearpass Fingerprinting - custom categories, and rules?
    Posted Mar 08, 2017 02:03 PM
    After creating the rule you don't see devices with the same OUI getting the new fingerprint?
    Get Outlook for iOS
  • 3.  RE: Clearpass Fingerprinting - custom categories, and rules?
    Posted Mar 08, 2017 02:14 PM
    No, I cant even see the rule... should I be able to view/edit/manage the created rule?  I also dindt retrospectively apply to devices I wanted to fingerprint, I had to select all, and manually fingerprint them.
  • 4.  RE: Clearpass Fingerprinting - custom categories, and rules?
    Posted Mar 09, 2017 09:26 AM
    Just for my own learning did you create your new fingerprint rule under Administration > Dictionaries >>  Fingerprints  ???
    And you are saying that after you added it that you can not see it or edit it?
