ClearPass-ForcePoint integration
This thread has been viewed 27 times
  • 1.  ClearPass-ForcePoint integration
    Posted Nov 12, 2019 07:10 PM
    ¿Is it possible to integrate ClearPass with Forcepoint?
  • 2.  RE: ClearPass-ForcePoint integration
    Posted Nov 13, 2019 12:28 PM
    Can you expand on integrate? What are you trying to do?
  • 3.  RE: ClearPass-ForcePoint integration
    Posted Nov 13, 2019 07:57 PM
    Hi Tim.
    We are looking for something similar to the integration and exchange of information carried out by ClearPass and Palo Alto.
  • 4.  RE: ClearPass-ForcePoint integration
    Posted Nov 14, 2019 03:36 AM
    Please reach out to ForcePoint. I have seen a document that covers the integration with ClearPass authored by ForcePoint.
  • 5.  RE: ClearPass-ForcePoint integration
    Posted Nov 26, 2019 05:49 AM
    To sent the username, try to use "Accounting Proxy" in the service, you can see the integration guide with Fortinet, as example.
    And to make actions, build your own dictionary and sent the logs via syslog to CPPM. I'll recommend you to put a "Syslog Proxy" between them to filter logs.
    Good luck.
    See this post (in Spanish I'm sorry)
    3rd party integration using IEE
    Hope this helps
