Clearpass full backup
This thread has been viewed 68 times
  • 1.  Clearpass full backup
    Posted May 05, 2023 09:35 AM
    as I saw the clearpass (6.10) auto backup just backups a few configurations.
    How do I manage to auto backup everything (system settings, PolicyManger Settings, Guest setting, ...)
    It would be nice if this is possible in case of a complete Outage and the upcoming 6.11 upgrade.
  • 2.  RE: Clearpass full backup
    MVP GURU
    Posted May 05, 2023 09:39 AM
    Have you set up the external Backup Server?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: Clearpass full backup
    Posted May 05, 2023 09:50 AM
    yep its set up and working, but for example the guest settings are not in the backup file.
  • 4.  RE: Clearpass full backup
    Posted May 05, 2023 11:14 AM
    A complete copy of the Guest configuration can be exported by:
    Guest > Administration > Import Configuration > "Create a customized backup"
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 5.  RE: Clearpass full backup
    Posted May 05, 2023 11:47 AM
    Yeah I also saw this. I'm searching for an automated way to backup all Clearpass configuration.
  • 6.  RE: Clearpass full backup
    Posted May 08, 2023 04:08 AM
    What makes you think that Guest settings are not stored in the backup? I've made multiple backup-restores and Guest, Onboard, etc normally comes with the backup. You would need to manually import certificates and rejoin to the domain in case you need MSCHAPv2 authentication. If you restore to a different system, some system specific settings (licenses, IP, routing, etc) are not restored either.
    So everything, except for licenses and domain join should be in the backups.
  • 7.  RE: Clearpass full backup
    Posted May 08, 2023 09:01 AM
    When I have a look in the backup file, which is generated by auto backup, I don't see any guest related stuff.
    And the file is just a few MegaBytes big.
  • 8.  RE: Clearpass full backup
    Posted May 10, 2023 05:34 AM
    I agree that it looks like guest is not included, but in my experience when restoring the config is there.
    Please check (preferred on a test VM) and if you see issues, contact support.
  • 9.  RE: Clearpass full backup
    Posted May 11, 2023 04:37 AM
    Guest config is included with ClearPass config backup. Server specific settings like AD domain join, static routes, certificates, licenses and custom service parameters are not included in the config backup.
  • 10.  RE: Clearpass full backup
    Posted May 11, 2023 08:56 AM
    Does that include ClearPass Extensions, Guest User Accounts, and Guest Devices?
  • 11.  RE: Clearpass full backup
    Posted May 11, 2023 12:24 PM
    Yes. Extensions, guest user accounts and devices are included in ClearPass config backup. So is guest config like pages, airgroup settings etc.
  • 12.  RE: Clearpass full backup
    MVP
    Posted May 12, 2023 07:23 AM
    I know this does not directly relate to the original question, but it is possible to separately backup Guest or parts of Guest, The UI navigation is not too intuitive IMO.
    In ClearPass Guest, go to Administration->Import Configuration->Import Configuration->Create a customized backup (upper right).
    From there, you can either perform, name, & download a Complete Backup or perform  Custom backup, selecting what parts you wish to include.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employerBruce Osborne ACCP ACMP
    Liberty University
  • 13.  RE: Clearpass full backup
    Posted May 16, 2023 07:43 AM
    are also private and public files and changes to skins included?
  • 14.  RE: Clearpass full backup
    Posted May 18, 2023 02:50 AM
    Custom skins purchased from Aruba is not included in backup however customizations done to existing skins are included. Private and public files are included in backup.
