clearpass guest
  • 1.  clearpass guest
    Posted Feb 14, 2017 10:20 AM
    We got a client which use clearpass guest and they use their office365 credentials to get in the network using clearpass guest
    They are limited by 2 devices for each user
    The client was asking if there is a way that the client can control himself his devices
    For example he has his ipad and his iphone alredy registered.   They have to manually delete that device entry from the endpoint repository to let a new device to get in the network
    What we would like to do is that the client can do it themselft wihtout IT intervention..
    I know you could do that but with clearpass onboard i beealive but they don thave that, right now.
    It is possible to do it in someway with what he had? just clearpass guest.
    Cheers
    Carlos
  • 2.  RE: clearpass guest
    Posted Feb 14, 2017 10:27 AM
    Unfortunately not natively. You could, however, build your own portal that
    leverages the REST API.
  • 3.  RE: clearpass guest
    Posted Feb 14, 2017 10:53 AM
    Tim Sorry
    What do you mean with REST API?
    With that is possible that the user can manage his own devices?
  • 4.  RE: clearpass guest
    Posted Feb 14, 2017 11:04 AM
    The REST API could be used with a custom UI to allow users to manage their
    devices.
  • 5.  RE: clearpass guest
    Posted Feb 14, 2017 11:06 AM
    Where can i get more info aobut rest api i would like to know how to test that... to see if i can do a lab or something>?
    Some manual or anything
    Cheers
    Carlos
  • 6.  RE: clearpass guest
  • 7.  RE: clearpass guest
    Posted Feb 14, 2017 11:13 AM
    thank you tim
