can someone please tell me how I can set Guest accounts to have the default setting as "not expire"?
I would have a look at the parameter/variable called "Expire_Time"
"Optional date and time at which the visitor accounts will expire and be deleted. If blank, the account will not expire."
JF
I've had a look at this, where/how do I change ti?
Are you using Guest Self-Registration or Guest Manager "Add Guest Account" to add accounts ?JF
It's for self registration
Ok, Great.
For Self-Registration, go to:
1) Configuration
2) Guest Self-Registration
3) Click the page you are using for Self-Reg and click edit
4) select the 'form' under 'register page'
5) in there you should find the variable expire_time
Thanks I've found the form fine, which value do I need to leave blank? Thanks for your help.
Thanks for yuor help, I've worked it out and it's all working great. Thanks again.
Thanks for the update.
Glad to hear its good-to-go!
