Clearpass Guest Active Session Timeout
  • 1.  Clearpass Guest Active Session Timeout
    Posted Dec 17, 2014 11:32 AM
    We are using Clearpass 6.4.0
    We are seeing high session count from our Guest users. Every time a new users joins the network it creates a new session that doesn't seem to ever time out.
    We have a captive portal setup that only requires an acceptance of our AUP to proceed. We use a local user (GuestAuth) to authenticate to Guest.
    The problem we see is each user that connects, creates a new session. The number of sessions just continues to grow.
    How can we expire sessions that are >24Hours?
  • 2.  RE: Clearpass Guest Active Session Timeout
    Posted Dec 17, 2014 11:42 AM
    Do you have Interim Accouting enabled ?
  • 3.  RE: Clearpass Guest Active Session Timeout
    Posted Dec 17, 2014 11:48 AM
    I can't remember off the top of my head where interim accounting is located in the profile. Could you direct me please? I'd like to verify before I give an answer.
    EDIT:
    I found it. Configuration > Wireless > AP Configuration >  Wireless LAN > Virtual AP > {VAP Profile} > AAA
    And yes. Interim accounting is enabled.
    Should I have User Idle timeout enabled and a time specified? Would that make a difference?
  • 4.  RE: Clearpass Guest Active Session Timeout
    Posted Dec 17, 2014 12:23 PM
  • 5.  RE: Clearpass Guest Active Session Timeout
    Posted Dec 17, 2014 12:47 PM
    Yes it is enabled on the Controller and on CPPM.
  • 6.  RE: Clearpass Guest Active Session Timeout
    Posted Dec 17, 2014 01:15 PM
    You add this into your policy
