ClearPass Guest and IOS XE
  • 1.  ClearPass Guest and IOS XE
    Posted Jan 14, 2014 10:25 AM
    Hello
    I've previously set up ClearPass Guest with Cisco WLC running IOS 7+ and that has been pretty straight forward.
    Now trying the same with a Cisco WLC 5760 running IOS XE 3.3.1, but can't get it to work.
    I'm redirected to the WLC (the local Radius auth pops up in Access Tracker), but then it stops with a "empty response" message from the WLC. If I reload this page I get a "Authentication Proxy Login Page"  (https://<name of WLC>/login.html?redirect=redirect)
    The login method used is:
    "Controller-initiated - Guest browser performs HTTP submit"
    Any suggestions? Or can link me to any updated guides for doing Cisco WLC and ClearPass Guest?
  • 2.  RE: ClearPass Guest and IOS XE
    Posted Jan 14, 2014 04:31 PM
    I think that you should be seting the 5760 up to do cwa like you would on the 3850 etc;
    An example of one done by an Airhead;
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Clearpass-guest-access-portal-MAB-web-authentication/td-p/110919
    So not like th "old" way of using external web auth.
    an exapmle of 5760 config Im working on in the lab but have had time to complete;
    aaa authorization network cwa_macfilter group Radius-Server-grp
    wlan test_cwa 1 test_cwa
    aaa-override
    accounting-list cppm
    exclusionlist timeout 5
    ip access-group GUEST
    ip dhcp required
    ip dhcp server 192.168.245.245
    mac-filtering cwa_macfilter
    nac
    peer-blocking drop
    no security wpa
    no security wpa akm dot1x
    no security wpa wpa2
    no security wpa wpa2 ciphers aes
    security dot1x authentication-list cppm
    no security ft over-the-ds
    session-timeout 1800
    ip access-list extended ACL-REDIRECT
    deny udp any eq bootps any
    deny udp any any eq bootpc
    deny udp any eq bootpc any
    deny udp any any eq domain
    deny tcp any any eq domain
    deny ip any host 192.168.246.220
    deny ip any host 192.168.245.245
    permit tcp any any eq www
    permit tcp any any eq 443
    ip access-list extended GUEST
    permit udp any host 192.168.245.245 eq domain
    permit tcp any host 192.168.246.220 eq 443
    deny ip any 192.168.0.0 0.0.255.255
    permit ip any any
    Hth
  • 3.  RE: ClearPass Guest and IOS XE
    Posted Jan 15, 2014 03:22 AM
    Thanks for the reply!
    Using CWA would mean using CoA and the Cisco tech here says that 5760 on this sw doesnt support rfc3576 - just rfc5176. I'll try and see how it goes, but Im not feeling lucky..
    Mvh
    John Solberg
  • 4.  RE: ClearPass Guest and IOS XE
    Posted Jan 28, 2014 09:59 AM
    Hello!
    Still working on this issue. I've setup things according to the guides for CWA (Centralised Web Access), but I'm not getting passed the first MAC-auth (MAB).
    The steps involved:
      First: MAC-AUTH with resulting in Cisco:AVPair redirect and remember cached role/results
      Second: Web Auth
      Third: MAC-Auth using Cached result from previous step
    Here we never got passed the first MAC-Auth due to CP doing Reject instead of Accept.
    Here is some of the errors from the log:
    2014-01-15 13:45:09,524
    [Th 21 Req 144 SessId R00000090-01-52d682d5] INFO RadiusServer.Radius - rlm_sql: searching for user 002710793968 in Local:localhost
    [RequestHandler-1-0x7ffcc9568700 r=psauto-1389710650-295 h=127 r=R00000090-01-52d682d5] INFO Core.ServiceReqHandler - Service classification result = Guest - Guest MAC Authentication
    2014-01-15 13:45:09,525
    [Th 21 Req 144 SessId R00000090-01-52d682d5] INFO RadiusServer.Radius - rlm_sql: found user 002710793968 in Local:localhost
    [Th 21 Req 144 SessId R00000090-01-52d682d5] INFO RadiusServer.Radius - rlm_macauth: Password in request doesn't match username. Not attempting MAC authentication
    So as far as I can tell ClearPass isn't accepting that Cisco sends User_Password as an encrypted version of the username (mac address).
    I've read in some Cisco documentation that atleast on switches it's possible to activate mab eap to force the User_Password to be sendt in cleartext. That could be a solution, but I haven't figured out how to configure that on a WLC v3.3.x
    Any tips of how to proceed?
  • 5.  RE: ClearPass Guest and IOS XE
    Posted Mar 10, 2014 06:03 PM
    Hello!
    We got this working eventually, so I thought I'd just close to thread with some final input.
    Atleast in 6.2.x using login-method "Controller initiated" doesn't work towards IOS XE (5760, 3850).
    Need to use login-method "Server initiated" which means CoA. This method is used for wired switches and referenced as MAB or MAC-filtering.
    There is no guide available anywhere that has this described in detail for IOS XE. On the ClearPass side the best guide I've come across is actually created by Alcatel-Lucent:
    http://www.youtube.com/watch?v=gVUUE59ptPI
    Cisco as created it's share of guides with 5760 and ISE, but they won't work directly off the bat for ClearPass:
    https://supportforums.cisco.com/document/147096/converged-access-%E2%80%93-configure-ssid-central-web-authentication-cwa-using-ise-catalyst
    That said - I still don't know what setting on Cisco that got things working since I wasn't the one troubleshooting that end. We had an Aruba engineer remote control the Cisco WLC and tried things back and forth until it worked. It was just too messy to get a final idea of what solved it ;(
    Important notes on the cisco config
     * If you're not getting passed the initial mac-auth to trigger the redirect try this line highlighted in bold:
    aaa group server radius clearpass_guest
    server name clearpass.domain.com
    subscriber mac-filtering security-mode mac
    * Redirect is triggered, but client is unable to open the CP page.
    Go through the redirect-acl in detail. This is what worked for us and is a variation of what you find on the cisco forums:
    ip access-list extended allowclearpass
    deny ip any host <clearpass-ip>
    permit tcp any any
    permit udp any any eq bootpc
    permit udp any eq bootpc any
    permit udp any eq domain any log
    permit udp any any log
    Good luck!
