Clearpass Guest - Authorization Attributes
  • 1.  Clearpass Guest - Authorization Attributes
    Posted Mar 28, 2019 04:36 PM
    When using the Guest User Repository as an Authorization Source, I am able to see 'AccountEnabled' and the 'AccountExpired' attributes returned during MAC Auth. Is it possible to return other attributes?
    I am looking for a way for a customer to be able to extend a Guest Expiration time through the Guest / Manage Accounts interface. Although it can be modified it doesnt help. As we know, the MAC Auth service looks at the Endpoint repository for the MAC-Auth Expiry attribute and not the Guest User Repository (with the newly modified expiry). I was hoping I can just look at the Expire attribute directly in the Guest User Repository instead however I cant seem to reference this field in the MAC Auth policy.
    Any ideas?
  • 2.  RE: Clearpass Guest - Authorization Attributes
    Posted Mar 28, 2019 04:39 PM
    Both expire_time and remaining_expiration are available by default.
  • 3.  RE: Clearpass Guest - Authorization Attributes
    Posted Mar 28, 2019 04:52 PM
    I am not seeing it. Check the attached details. Maybe I am overlooking it?
    Attachment(s)
    txt
    Dashboard_Details.txt   5 KB 1 version
  • 4.  RE: Clearpass Guest - Authorization Attributes
    Posted Mar 28, 2019 05:15 PM
    You'll need to edit the [Guest User Repository] auth source.
    Under attributes, click Authorization.
    Replace the entire query with:
    SELECT
           CASE WHEN expire_time is null or expire_time > now() THEN 'false'
           ELSE 'true'
           END AS is_expired,
           CASE WHEN enabled = true THEN 'true' ELSE 'false' END as is_enabled,
           CASE WHEN expire_time > now() THEN CAST(EXTRACT(epoch FROM (expire_time - NOW())) AS INTEGER)
                ELSE 0
           END AS user_remaining_expiration
    FROM tips_guest_users
    WHERE ((guest_type = 'USER') AND (user_id = '%{Endpoint:Username}') AND (app_name != 'Onboard'))
    In the editor, add a new attribute: user_remaining_expiration // User Remaining Expiration // Integer
    Screen Shot 2019-03-28 at 5.13.58 PM.pngUse that new attribute in your policy. Remember, the attribute won't be pulled (and thus wont' be visible in AT) unless you evalute it either in role mapping or enforcement.
  • 5.  RE: Clearpass Guest - Authorization Attributes
    Posted Mar 29, 2019 08:31 AM
    That works perfectly. Thanks Tim!
