ClearPass Guest Automatization
  • 1.  ClearPass Guest Automatization
    Posted Aug 01, 2016 06:15 AM
    Hi guys,
    I've got several questions regarding captive portal automatization and specialized configuration:
    Situation 1:
    Guest Captive Portal with sponsor confirmation.
    Guest has registered and is waiting on sponsor confirmation (at the receipt page)
    Sponsor confirms access for the user
    Question 1:
    Can I auto-submit the receipt page the moment the button becomes available (when guest user is accepted by sponsor)?
    Situation 2 (with 2 questions):
    Due to device limitations in onboard, we are searching for a workaround. We want to make users login with AD credentials to a web portal (like in onboard) but instead of certificate installation, they will generate a guest user to use for their device.
    Flow is as following: login page -> registration page -> receipt page
    User logs in, the registration page only has a field for username/email. Password will be a generated one. User will submit registration page to create user.
    Question 2:
    Can I automatically get their email address from AD to use or their username and let it be filled in on the registration page?
    Example: user logs in, username field is filled in automatically with the username or email address.
    Question 3 (only if question 2 is possible):
    Can I again automatically submit the page to create the user?
    Kind regards,
    jcelis
  • 2.  RE: ClearPass Guest Automatization
    Posted Aug 02, 2016 05:47 PM
    Anybody got any idea?
  • 3.  RE: ClearPass Guest Automatization
    Posted Aug 02, 2016 05:56 PM
    What ClearPass licenses do you own?
  • 4.  RE: ClearPass Guest Automatization
    Posted Aug 03, 2016 03:36 AM
    Guest, onboard, onguard and policy manager.
    Thanks for answering but don't see how the licenses are relevant for this. Just looking if I can and how to pull data from a login screen into a registration field and automatically submit the data.
  • 5.  RE: ClearPass Guest Automatization
    Posted Aug 23, 2016 04:58 PM
    Re: Question 1:
    Yes, you can detect when a user is "approved" by a sponsor when they're sitting on that receipt purgatory page:
    {if $user.enabled}
    USER IS ENABLED!!
    {/if}
    You can combine that with the auto-submit script, slightly modified, available on Arubapedia:
    {if $user.enabled}
      {literal}
        <script>
          $( document ).ready(function() {
            Nwa_SubmitForm(_form_name,"ID_"+_form_name+"_submit"); // submit the form
        </script>
      {/literal}
    {/if}
    Questions 2/3 seem doable as well, probably with additonal Javascript.
    You can grab the username (email address) via the PHP smarty variable:
    {$username}
    Refer to the https://arubapedia.arubanetworks.com/afp/index.php/ClearPass_Guest_HTML_Cheatsheet for more tricks to help you with Questions 2/3.
  • 6.  RE: ClearPass Guest Automatization
    Posted Aug 29, 2016 11:31 AM
    Thanks for the reply. Knew I had to go to javascript to get this done. Also got some code from a colleague with how to retrieve information with LDAP and how to store it for the next page.
    Probably won't implement it right now.
  • 7.  RE: ClearPass Guest Automatization
    Posted Sep 20, 2016 07:00 PM
    Keep us posted and feel free to share your code snippets if you need help troubleshooting!
