Clearpass Guest - Captive Portal is shown down
  • 1.  Clearpass Guest - Captive Portal is shown down
    Posted Jan 24, 2018 08:51 AM
    Hi Team:
    I've configured a captive portal with Clearpass, Aruba Controller 7030, IAP-315.
    My issue is that captive portal redirect page, however the captive portal is shown down
    I resolve the name with DNS, but when I type the captive portal URL on the different network the captive portal works.
    I've configured the Forward Lookup Zones and Reverse Lookup Zones on DNS Manager.
    I'm not using certificate on guest portal, so I configured HTTP enable.
    Any idea?
    Thanks for all!!
    Cheers
  • 2.  RE: Clearpass Guest - Captive Portal is shown down
    Posted Jan 25, 2018 03:02 AM
    Hi, are you able to show a picture of what you mean by "down"?
    It sounds like there is possible something wrong with your user role.
  • 3.  RE: Clearpass Guest - Captive Portal is shown down
    Posted Jan 26, 2018 12:16 PM
    Hi...
    Thanks for your replay.
    I attach the capture.
    When I connect to Guest SSID, web browser automatic display the URL, but it doesn't show the guest portal.
  • 4.  RE: Clearpass Guest - Captive Portal is shown down
    Posted Jan 26, 2018 12:46 PM
    1) There appears to be a space between s and . in the URL
    2) You likely do not own "clearpass.com" so not sure why you're trying to use that
  • 5.  RE: Clearpass Guest - Captive Portal is shown down
    Posted Jan 26, 2018 01:13 PM
    Hi....
    Actually, I edited the url.
    I configured the name aruba.clearpass(company-name).com
    the guest url is http://aruba.clearpass.com/guest/teslogin.php
  • 6.  RE: Clearpass Guest - Captive Portal is shown down
    Posted Jan 26, 2018 04:51 PM
    In your browser, enter http://1.1.1.1 and see if you are redirected.
