last person joined: 8 hours ago
Clearpass Guest / Clearpass portal
  • 1.  Clearpass Guest / Clearpass portal
    Posted Feb 14, 2013 03:29 AM
    Hi guys
    I'm tryin to set up Clearpass Guest and am having some issues with the captive portal. I've redirected my guest users to the url:https://x.x.x.x/guest_portal.php and instead of getting my amigopod-like guest registration page, I'm getting the CPPM Guest Portal (see attachment).
    I'm sure there must be something really simple that I'm missing, but I haven't been able to find it.
    Thanks for the help
    Regards
  • 2.  RE: Clearpass Guest / Clearpass portal
    Posted Feb 14, 2013 06:19 AM
    On ClearPass Guest if you click on the Test login button on your web login page do you see the correct login page? What is the URL of this?
    What URL is in your Captive Portal profile?
    These two have to match and you also need to allow the access in your guest logon role to the ClarPass server.
  • 3.  RE: Clearpass Guest / Clearpass portal
    Posted Feb 14, 2013 09:56 AM
    That did the trick, thanks!
