Clearpass Guest - Configuring a new field in a guest captive portal.
  • 1.  Clearpass Guest - Configuring a new field in a guest captive portal.
    Posted Jul 16, 2018 09:51 AM
    Hi.
    I've configured a guest captive portal with sponsor approval, everything is working.
    Now, the customer wants to add some questions like; ie
    where do you work?
    What do you think about our services? (Option box field)
    I created the question here:
    However, I don't know how can I insert this field in Form:
    How can I add the new field in this section?
    Thanks in advance
  • 2.  RE: Clearpass Guest - Configuring a new field in a guest captive portal.
    Posted Jul 16, 2018 09:55 AM
    Click an existing field and click Insert Before or Insert After.
  • 3.  RE: Clearpass Guest - Configuring a new field in a guest captive portal.
    Posted Jul 16, 2018 10:38 AM
    Thanks for your reply:
    I found it.... i'ts working.
