ClearPass guest Controller Redirect
  • 1.  ClearPass guest Controller Redirect
    Posted May 30, 2017 07:33 AM
    deleted
  • 2.  RE: ClearPass guest Controller Redirect
    Posted May 30, 2017 08:58 AM
    Not quite sure I understand this part :
    "The Android device dind´t not use the FQDN for the redirect - it uses the IP Adress and the certificate is only valid for the FQDN."
    So even when you redirect the device to the URL the device gets redirected to the IP ?
    Get Outlook for iOS
  • 3.  RE: ClearPass guest Controller Redirect
    Posted May 30, 2017 09:03 AM
    It was a mistake on my site.
    Everything is working fine. If you redirect the user from the controller to the clearpass by using the FQDN every device is using it.
    missconfiguration on my site. Please delete this Topic.
