Do you have the luxury to call TAC for this ?
Coz I too have similar issue, with this mac_import page, cannot customize it. And TAC said he needs some time to test it in his lab.
About the mac_export to export only the not expired accounts, possible if you do it in Excel ? Or maybe you just delete the expiry date column , or set to will not expire.
Original Message:
Sent: Jun 29, 2022 05:04 AM
Subject: ClearPass Guest - Customize accounts import template
Hi everyone,
Does anyone know if there is an option to customize the exporting template for the accounts in ClearPass Guest?
I do know tha you can customize the exported columns (add or remove columns) but I want to export only the NOT EXPIRED accounts as the maximum number of accounts that I can import to another ClearPass is 1000 at maximum.
Thanks!
