Clearpass Guest Deployment
  • 1.  Clearpass Guest Deployment
    Posted Jul 26, 2016 05:10 PM
    Hi Guys,
    I just wanted to run something by you guys for a Clearpass Guest Deployment.
    One of my clients is looking to deploy a basic guest wireless from an Instant Access point. They want the users to input the pre-shared key and after that they would like them to get a captive portal page where they accept the terms and conditions.
    The problem is with the captive portal page. Here is some basic info on the deployment:
    • 30 sites with 1 IAP at each site broadcasting the SSID
    • The IAP is attached to a broadband router, which is attached to an ADSL line
    • It is very unlikely that these 30 sites have direct connectivity with each other. I.e no MPLS network to link them together or WAN so we will be relying on the Internet
    I wanted to ask you guys to clarify the following:
    • How will the IAP communicate to the centrally hosted clearpass server?
    • How do I add these IAP’s into Clearpass as they will have a 192.168.x address from the router
    • What kit list is required from Clearpass, i.e I know I need the Clearpass server & licenses, but have I missed anything else?
    Hope you guys can answer my request with a nice easy solution J
  • 2.  RE: Clearpass Guest Deployment
    Posted Jul 27, 2016 03:20 AM
    You'll have to provide a public reachable address for the clearpass. Source NAT for the 2nd question
  • 3.  RE: Clearpass Guest Deployment
    Posted Jul 27, 2016 03:54 AM
    Note regarding the first bit: if you're using DNS name instead of IP address, you'll also need a publically resolvable address. guest.company.com/guest/page.php has to lead them to your ClearPass from the internet. This will be a public address.
    You can use destination NAT for masking your ClearPass behind that public address.
