Clearpass Guest Device Database
  • 1.  Clearpass Guest Device Database
    Posted Jun 01, 2016 10:52 AM
    Hi All
    I'm looking at using the Clearpass Guest Device Database as an authentication source for our MAC auth devices (barcode scanners and dataloggers etc.) rather than a static host list. Can anyone tell me if doing this will use guest licenses as well as CPPM licenses, we have a limited number of guest licenses so would rather only use them for actual guests. I have read through loads of the posts on Clearpass licensing but couldn't find any reference to the device database.
    And thanks to Tim Cappalli for the tip on using the Guest Device Database.
    Dave
  • 2.  RE: Clearpass Guest Device Database
    Posted Jun 01, 2016 11:09 AM
    No, device registrations do not consume guest licenses, only base
    authentication licenses.
  • 3.  RE: Clearpass Guest Device Database
    Posted May 03, 2017 01:02 AM
    Is it still true? I have a customer using Guest Device DB only, it seems the guest license is consumed. Anyone from Aruba can you please confirm? Thanks.
  • 4.  RE: Clearpass Guest Device Database
    Posted May 03, 2017 02:01 AM
    Yes it is true. You Need to make sure they are using the guest device db not the guest user db. If you are still having issues then please open a TAC case
