I have a MacTrac device registration implementation based on the following: http://community.arubanetworks.com/t5/Security/How-To-Advanced-Device-Registration-in-ClearPass-November-MHC/td-p/217291
One issue I have noticed is that when an end user removes a previously created device from within CPG it does not also remove it from the Endpoints Repository.
Is there any magic you can think of that might work around this?
Cheers
Shaun
I also see a vice versa,
Whereby a device is MAC Authenticated with User Caching but does not show up within CPG.
Any ideas on how to marry the two together?
Hmm.. Can you verify that you are indeed using Guest Device Repository as authentication source? It sounds like you are using Endpoint Repository - which is the more common/default MACAUTH implementation
Don't think you read the whole post there Tim. His mac-auth service doesn't take into account the state of the device in the Guest Device Repository. If the device was removed in Guest Device Repository - the mac-auth should fail. To me that looks like it's authenticating based purely on Endpoint database information.
Yep spot on it was a misconfigured service, I have configured how you described and all is now Ok.
Thanks all
Chhers
