Clearpass Guest Device Sponsor Name
  • 1.  Clearpass Guest Device Sponsor Name
    Posted Nov 02, 2017 07:06 AM
    I have a MacTrac service that allows end users to create their own devices. I have a web auth service that catches these created devices but I'm struggling to check if the sponsor name exists within AD.
    When I use the following mapping:
    (Authorization:[Guest Device Repository]:SponsorName  EXISTS   )
    I see the AccountStatus, RemainingExpiration and SponsorName attributes to match against.
    With this in mind I have created the following AD filter and added AD to my list of authorization sources.
    Filter Name: Sponsor Name Check
    Filter Query: (&(objectClass=user)(sAMAccountName=%{Authorization:[Guest Device Repository]:SponsorName}))
    Name:memberOf, AliasName:Sponsor Name AD Group, DataType:String
    When I map against the following I don't get any authorization attributes from the AD source
    (Authorization:Active Directory:Sponsor Name AD Group  EXISTS   )
    Any ideas on where I might be going wrong?
    Cheers
    Shaun
  • 2.  RE: Clearpass Guest Device Sponsor Name
    Posted Nov 02, 2017 08:40 AM
    Do you have that AD authentication source as an additional authorization source in your service?
    Also, better to use UserDN EXISTS.
  • 3.  RE: Clearpass Guest Device Sponsor Name
    Posted Nov 02, 2017 09:27 AM
    As ever Tim thanks for the reply,
    AD is definatley in as an authorization source.
    This is what I see when I use UserDN Exists,
    Any ideas?
    Cheers
    Shaun
  • 4.  RE: Clearpass Guest Device Sponsor Name
    Posted Nov 02, 2017 09:49 AM
    Test it by putting the same username in the field on the Attributes tab of the Authentication filter of the authentication source.
  • 5.  RE: Clearpass Guest Device Sponsor Name
    Posted Nov 02, 2017 10:31 AM
    Sorry I could not get this to work but instead I'm using the following you sorted for someone else.
    http://community.arubanetworks.com/t5/Security/Using-ClearPass-guest-device-registration-for-additional/m-p/311814
    The SQL for the Role ID works very well for my specific purpose so I'm happy downing tools on the AD/SponsorName side of things.
    Thanks again for your help
    Cheers
    Shaun
