very simple question but can't seem to find it in the documentation.
is in clearpass guest (version 6 if it matters) the difference between "Save Changes" and "Save and Reload" button only if you stay on the page or return to the page before it?
hmm odd, with me it just shows the same page in the same tab. anyway the effect is the same right, the configuration is saved?
Correct. The save and reload is just handy way of you previewing your page when you are done editing it. I have see your issue only when popup blocker is enabled.
What browser are you using i would like to see if I can replicate your issue?
Thank you,
Troy
took a while, but tested it today and it works like you explain, probably browser issue before.
