Clearpass guest id
  • 1.  Clearpass guest id
    Posted May 16, 2022 07:24 PM
    We wonder if there is any technical or security reason for guest id in clearpass to be only email adress or generated username.
    We found that having phone number as id should be possible in a "workaround" way (modifying email address filed to fit for phone number).
    Anyway to use the base phone field as id or xis there any reason that prevent it ?
    BILLOT Emmanuel
  • 2.  RE: Clearpass guest id
    Posted May 20, 2022 11:18 AM
    Changing the email field to a phone number type may work, I'm just not 100% sure if having a + in usernames may result in issues. Should be easy to test/setup.
