Aruba Central
Clearpass Guest Login
This thread has been viewed 21 times
  • 1.  Clearpass Guest Login
    Posted Jan 05, 2023 12:07 AM
    Hi everyone,
    i have a task to remove the black background of the login and color it with the same bg-color blue. Is that possible in Clearpass?
    BR Manuel
  • 2.  RE: Clearpass Guest Login
    Posted Jan 05, 2023 04:58 AM
    You can probably edit the CSS or colors in the Skin configuration. Check this video.
