ClearPass guest login after watching a video
  • 1.  ClearPass guest login after watching a video
    Posted Oct 20, 2017 04:33 AM
    I would like to create Clearpass guest captive portal, where internet would only be after the user watched a video.
    After the user has internet access, some intervals other videos pop up and the user has to watch it.
    Is that possible in clearpass? If the answer is yes, how can i do that?
    Thank you.
  • 2.  RE: ClearPass guest login after watching a video
    Posted Oct 20, 2017 09:11 AM
    Where does the video live?
    This is generally not recommended.
  • 3.  RE: ClearPass guest login after watching a video
    Posted Oct 20, 2017 09:20 AM
    There is a captive portal, where there is terms and conditions, but the user can only accept it when the video will be end.
  • 4.  RE: ClearPass guest login after watching a video
    Posted Apr 04, 2018 05:53 AM
    You could add a javascript code to confirm when video ends and enable the register button by javascript.
    I think this solution is good for marketing but it could give you problems regarding the javascript in some browsers. If it fails, the user couldn't access to the network and the experience could be bad. It depends of your javascript code :)
  • 5.  RE: ClearPass guest login after watching a video
    Posted Apr 04, 2018 02:36 AM
    I think a video is great for marketing purpose.
    So, anyone tested access for guests after watching a video?
    Thanks.
