ClearPass Guest - Logins are not currently available
  • 1.  ClearPass Guest - Logins are not currently available
    Posted Aug 03, 2018 12:41 AM
    HI all,
    Just tried using stock install of ClearPass 6.7.2 in Workbench.
    Getting an error when trying to use network login from Guest Self Registration. If i create a separate web login form it works fine so it seems to only be the guest registration.
    I tried creating a new self registration page but its still the same issue.
    Self registration is enabled and network login via NAS is enabled.
    Also tried upgrading to 6.7.5 but still the same. Any ideas?
  • 2.  RE: ClearPass Guest - Logins are not currently available
    Posted Aug 03, 2018 04:36 AM
    Could it be that you don't have any Access Licenses?
  • 3.  RE: ClearPass Guest - Logins are not currently available
    Posted Aug 05, 2018 05:37 PM
    i checked that but the server is fully licenced (its in Workbench).
  • 4.  RE: ClearPass Guest - Logins are not currently available
    Posted Aug 05, 2018 05:38 PM
    it seems that the universally accepted solution (reboot) fixed this.
    problem solved!
